I have an issue printing Emoji icons.
They show in the preview, but when printing it returns an error.
is there a workaround?
LoggedApplicationException: There was an error running the data mapping process caused by Error executing DM configuration: DB Error during DM result persist worker (DME000150)
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.7.1.v20171221-bd47e8f): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.BatchUpdateException: Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30
Error Code: 1366
Error Code: 1366
Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30 (DM1000031)
{“error”:{“status”:500,“message”:“LoggedApplicationException: There was an error running the data mapping process caused by Error executing DM configuration: DB Error during DM result persist worker (DME000150)\n Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.7.1.v20171221-bd47e8f): org.eclipse.persistence.exceptions.DatabaseException\r\nInternal Exception: java.sql.BatchUpdateException: Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30\r\nError Code: 1366\n \r\nInternal Exception: java.sql.BatchUpdateException: Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30\r\nError Code: 1366\n Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30\n Incorrect string value: ‘\xF0\x9F\x98\x89\x0A\x0A…’ for column ‘DATA’ at row 30 (DM1000031)\n”,“parameter”:“”}}
