Hello good day
I have a soap process, which is always cut the connection at ~ 120000ms (2 min) but my process takes around 3 min. and it finish ok in pp console log.
Already setup http server imput time-out in 240 seconds (4 min) and client soapui in 4 min.
This same process in PP Suite 7.6 works correctly.
There is a problem with the timeout with PP Connect.
PD. when the pdf generation takes less than 2 minutes the process works OK
PD. 2 the SoapUI and Postman return:
<SubmitMessage xsi:type="xsd:string">SubmitJob: Failed: EHttpException - Timeout waiting for response file to be available</SubmitMessage>
but it finish ok in pp console log and generate ok the pdf.
Thank you!!!
