Good Day,
I am designing a template for a print context that will be 4-up. The template is 5.5 inches in height and 11 inches wide. This will be printed as duplex jo. The job will print on a tabloid (11 x17 inches) landscape paper. I am examining in Print – Advanced – Cut and Stack Imposition – Bleed margins. In the case of the bleed margins, I want to add 0.25 inch. I want to understand the impact of using the bleed margins in the output options of PP Connect:
From the infoirmation form the web, when I use bleed margins, at design time I should increase the master pages size 0.25 inch on all sides, increase any full color background on the master and also use a bigger paper then tabloid.
So in PP Connect, if I use the bleed margin option and adjusted to 0.25 inch, will it add 0.25 inch automatically on the 4 sides of each master or will shrink of 0.25 inch on all the side of the master?
I try to use PDF output but I do not the impact when I am using the bleed margins
The template is very simple, I just use as example to understand the output options.
Thank you
