frank
1
Good Day,
If you PP Connect design then open the Imposition Option Windows(
PP Connect Design – File - Print – Advance – Cut and Stack Imposition – Next button - Impositions Options)
In the Imposition Options window, there is check box – Rotate document 180 degrees .
So my question is the following: When you check this option does but the Final Media size as landscape or does turn final media up- side down?
If you a want portrait page to be landscape then it should turn 90 degrees. I have the on-line documentation and it does clarify this point.
Thank you and best regards
frank
2
Good Day to all,
So I did a little test, I am working with a N-UP template. The post-card size: width: 8.5 - height : 5. 5 inches.
I to print 4 up, so in Final Media , I choose the tabloid size: width: 11 inches - height: 17 inches thus it is set as portrait orientation
I check the option: Rotate document 180 degrees and print the job in PDF. I open the PDF, the result is the page is now landscape
Conclusion: Rotate document 180 degrees .options does rotate 90 degrees not 180 degrees
Thus is it an error in the title of this option or this should rotate 180 degrees
I now put this as some kinf of bug
I am using PP Connect design 1.0
Best regards
