I did test the PlanetPress Workflow using PlanetPress Connect Package file.
Previously, I got the output at the PlanetPress Connect Designer.
And then, I sent the Package file to the PlanetPress Connect Workflow.
I did setup the workflow the plugin such as “Folder Capture”, " Execute Data Mapping", Create Print Content", Create Output" and “Send to Folder”.
I did debug the step by step but the error was occurred.
So I would like to know why this error was occurred and get the solution.
In addition, It does not have enough to setup guide and techincal document, video clip and etc, to solve the workflow error.
If possible, Could you send me the sample workflow setup file and demo file?
Finally, How to upload the image(screen shot) and error log file at this site? I did not find the image upload directly. It just add the image url info.
************Error Message(PlanetPress Workflow) **************************************
Start 2015/02/11 14:11:59
PlanetPress Workflow v8.0.0.9363
Host: WIN-GGJM0KFKAB9; User: Administrator
Serial number: AU00D-510056-4922; Activation code: 0264-510056-1F24-841D-A5C5-859F
Service has started
Signaling Process “Internal Dynamic Process” to stop (2 of 2)…
Signaling Process “Process1” to stop (1 of 2)…
There are 0 replicated processes still running…
All Processes have terminated.
All helper services have stopped.
Service has stopped
2015/02/11 15:26:17
Start 2015/02/11 15:26:17
Service has started
Service has stopped
2015/02/11 15:33:51
Start 2015/02/11 15:33:51
Service has started
Process1 (thread id: 9996) - 15:34:15
File captured : C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\0.tmp\job00ZQQL0TDSUZ8152A303A10.dat, size: 415 bytes
Plugin Folder Capture completed successfully - 15:34:15 (elapsed time: 00:00:00:013)
Sending file data source…
W3001 : Error while executing plugin: HTTP/1.1 401 Unauthorized
Execute Data Mapping: W1603 : Plugin failed - 15:34:15 (elapsed time: 00:00:00:013)
W3001 : Error while executing plugin: W3886 : Metadata file to append: “C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\0.tmp\job00ZQQL0TDSUZ8152A303A10.dat.meta”, was not found
Create Print Content: W1603 : Plugin failed - 15:34:15 (elapsed time: 00:00:00:000)
W3001 : Error while executing plugin: W3886 : Metadata file to append: “%s”, was not found
Create Output: W1603 : Plugin failed - 15:34:15 (elapsed time: 00:00:00:018)
File sent : c:\out\test_20150211.csv, size: 415 bytes
Plugin Send To Folder completed successfully - 15:34:15 (elapsed time: 00:00:00:002)
Process1 (thread id: 9996) complete - 15:34:15 (elapsed time: 00:00:00:048)
Process1 (thread id: 9996) - 15:35:12
File captured : C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\0.tmp\job00ZQQL12P3DPZ332A31160D.dat, size: 415 bytes
Plugin Folder Capture completed successfully - 15:35:12 (elapsed time: 00:00:00:008)
Execute Data Mapping: W1603 : Plugin failed - 15:35:12 (elapsed time: 00:00:00:013)
W3001 : Error while executing plugin: W3886 : Metadata file to append: “C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\0.tmp\job00ZQQL12P3DPZ332A31160D.dat.meta”, was not found
Create Print Content: W1603 : Plugin failed - 15:35:12 (elapsed time: 00:00:00:001)
Create Output: W1603 : Plugin failed - 15:35:12 (elapsed time: 00:00:00:002)
Plugin Send To Folder completed successfully - 15:35:12 (elapsed time: 00:00:00:002)
Process1 (thread id: 9996) complete - 15:35:12 (elapsed time: 00:00:00:027)
