PlanetPress Connect Designer ... imposition flawed ???
Hello fellow helpers,
I’ve been trying to test the flexibility of the imposition feature within Connect Designer.
Can somebody please verify how one is able to impose A6 landscape (148mm width x 105mm height), 8up on SRA3 (450mm width x 320mm height) …
… I cannot seem to get the “Cut and Stack” feature on output to work with anything designed in landscape orientation (even A4 landscape won’t go 2up on SRA3) …
… what am I missing here ???
Many thanks for the assistance.
André
The trick is not to tell the print sections they are landscape. Just make them landscape by changing your height and width.
That makes them show up correctly in the preview and, more importantly, print correctly.
… thank you AlbertsN for the direction … the preview in the imposition was baffling me … and that “landscape” orientation option in designer was certainly causing me hours of confusion.
