Client producing concert tickets. The artwork was always 1up (190x70mm) and they added a counter using ‘Generate Counter’ and then imposed 4-up with crops onto a press sheet size. So there is a 4 to view once imposed. (00001, 00002, 00003, 00004) and steps so on.
They now receive the artwork 4-up with crops already on the PDF, as the job now gets perforated instead (end client prefers tear off as needed instead of singles as before)
Using the same ‘Generate counter’, how do i add the counter to read the 4-up/to view as before without duplicating the same range?
