I have a template that calls a lot of images and uses multiple data sources. The data runs fine if it’s 50 records or under, but if I have more than that, I get the following error:
[0005] W3001 : Error while executing plugin: HTTP/1.1 500 Internal Server Error - An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the output creation process caused by ApplicationException: Communication error (OUT000019)
I have tried both printing from Designer and sending through Workflow but I get the same results. I found a thread about this and it suggested to increase the memory usage in the WeaverEngine.ini. I opened that file but I couldn’t find -xmx in it. The instructions were:
I am using the latest version of PresConnect.
Any help would be appreciated.
Thank you,
