PDF / Print Simplex / Duplex
How can I arrange that the Print to the Printer will be Duplex and the PDF for the archive will be simplex?
I thought it would be possible with output preset Force Simplex. My SheetLayout is Duplex.
Nick
Hi Nick,
PDF output will normally ignore any duplex setting although if a record has an odd number of pages a blank page will be added automatically if the section is set to duplex.
In this case, if you need to prevent blank pages from being added to record with odd number of pages, you will need to create a new template for PDF output and disable the Duplex option in the section.
You may also achieve the same by using two sections. One for PostScript output in Duplex and the other for PDF output in simplex. Using a control script, you will need to disable one of the section depending on whether you are generating a PostScript output or a PDF output.
Rod
