PDF Output Blank Pages
When I output to PDF, for some reason every other page is showing as blank. It’s only showing page numbers on the pages with content, but it’s as if it’s showing the back side of the print context and saving that in the PDF.
Is there a way to prevent this from occuring? I have an NFR license, so I’m not sure if that’s an intentional feature or not to prevent use.
Thanks in advance
Is it possible you’ve set your template up as duplex?
When I click on sections, properties, I don’t have duplex printing selected. I also didn’t see anything in my print output that would cause it to be set up that way.
Is there any other place I should look?
To help you properly we would need to see the Template and reproduce the issue. I suggest you open a technical support call at 1-866-348-5863 or through our website.
