The workflow is relatively simple. A text file is dropped into a watchfolder and the csv filename is picked up off of this. This csv goes through a datamapper, print content and creates a job. some variables are then set with metadata and it then creates an output before being renamed and output to sharepoint.
When I debug through, I can view pdf at the rename element, at which point the pdf is correct in the preview window.
It outputs to sharepoint and I get a correctly named pdf, but the only content is our logo and the tables, but none of the data information, nor any information that has been typed in.
Any ideas where I have gone wrong?
