I have a template. I select “File”, “print presets”, and “output creation settings”.
The window that pops up defaults to configuration name “new” and output settings are Generic PDF.
I want to write a PCL job to a folder. So, I have created a configuration name genericpcl, with properties output type PCL, output local is false, output to directory, job output mask is ${template}. destination folder is on the desktop named testoutput, and was selected by navigating to the folder. I click “finish” and the window closes without a protest.
However, if I then immediately click file, print presets, output creation settings again, I see output settings are generic PDF still.
How to make this take? When I run the workflow using this output preset on the template and send output to file immediately after job creation, I do indeed get a generic PDF.
