org.eclipse.core.runtime.CoreException: removeArtifacts is not defined
I’m getting the following error in the All In One plugin:
[0006] W3001 : Error while executing plugin: HTTP/1.1 500 There was an error running the content creation process caused by Error: org.eclipse.core.runtime.CoreException: ReferenceError: removeArtifacts is not defined.
The template is a relatively simple “pull background from network, apply a few bits of personalisation and impose 1-up or booklet conditionally”. Re-running the same record lets it go through normally.
Can anybody offer any ideas what this is and how to prevent this?
Hi @puszczyk,
I would like to ask you kindly to open a technical support ticket via our ‘website’ because I suppose that we need to investigate the log files of PlanetPress Connect and possible the Template file you are using to find out why the reported error message does occur by executing the OL Connect “All in One” Workflow plugin.
