I have a Barcode in my template which will not render if it’s placed inside another DIV element (which is a parent element containing the barcode and the address block, and is positioned via a Control Script).
If I take the barcode out of the parent div and position as a top-level element (under “Body” in the normal, static, flow), it renders.
I need the barcode to render regardless of how/where it is positioned. Is this a bug or known issue?
