Hi, in Connect Designer i get this error and I don’t understand why. It’s happening when Previewing the Print Sections:
Error: org.eclipse.core.runtime.CoreException: NS_ERROR_FAILURE: Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIOLJavaCall.callJava].
org.eclipse.core.runtime.CoreException: Error: org.eclipse.core.runtime.CoreException: NS_ERROR_FAILURE: Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIOLJavaCall.callJava].
at com.objectiflune.contentcreation.html.mergeengine.impl.c.raiseError(c.java)
at com.objectiflune.contentcreation.html.mergeengine.impl.c.runAndWait(c.java)
at com.objectiflune.contentcreation.html.mergeengine.impl.a.merge(a.java)
at com.objectiflune.contentcreation.html.mergeengine.impl.HtmlMergeEngine.merge(HtmlMergeEngine.java)
at com.objectiflune.application.designer.editors.TemplateEditor.b(TemplateEditor.java)
at com.objectiflune.application.designer.editors.TemplateEditor.c(TemplateEditor.java)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at com.objectiflune.application.designer.editors.TemplateEditor.a(TemplateEditor.java)
at com.objectiflune.application.designer.editors.TemplateEditor.D(TemplateEditor.java)
at com.objectiflune.application.designer.editors.TemplateEditor.access$7(TemplateEditor.java)
at com.objectiflune.application.designer.editors.bg.run(bg.java)
at com.objectiflune.application.designer.shared.d.run(d.java)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at com.objectiflune.application.designer.editors.ag.run(ag.java)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at com.objectiflune.application.designer.editors.HtmlEditor.withoutRedraw(HtmlEditor.java)
at com.objectiflune.application.designer.editors.z.runInUIThread(z.java)
at com.objectiflune.application.designer.editors.HtmlEditor.runJob(HtmlEditor.java)
at com.objectiflune.application.designer.editors.TemplateEditor.onPageChanged(TemplateEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.pageChange(HtmlEditor.java)
at org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(MultiPageEditorPart.java:290)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2746)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1433)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.objectiflune.application.Application.start(Application.java)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: Error: org.eclipse.core.runtime.CoreException: NS_ERROR_FAILURE: Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIOLJavaCall.callJava]. in ‘KALLE~1.BYS/AppData/Local/Temp/jssysscr6814205398224847338.js’ at line 8546
Browser: CA_EN_XX_002
at com.objectiflune.layoutengine.html.js2java.JavascriptErrorHandler.onJavascriptError(JavascriptErrorHandler.java)
at com.objectiflune.layoutengine.html.js2java.JavascriptErrorCallback.function(JavascriptErrorCallback.java)
at com.objectiflune.layoutengine.html.embed.e.callJava(e.java)
at org.mozilla.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Native Method)
at org.mozilla.xpcom.internal.XPCOMJavaProxy.invoke(XPCOMJavaProxy.java:192)
at com.sun.proxy.$Proxy94.oL_evaluateJS(Unknown Source)
at com.objectiflune.layoutengine.html.embed.u.a(u.java)
at com.objectiflune.layoutengine.html.embed.u.evaluate(u.java)
at com.objectiflune.layoutengine.html.embed.Browser.evaluate(Browser.java)
at com.objectiflune.layoutengine.html.MozillaBrowser.a(MozillaBrowser.java)
at com.objectiflune.layoutengine.html.MozillaBrowser.evaluate(MozillaBrowser.java)
at com.objectiflune.layoutengine.html.pagination.k.run(k.java)
at com.objectiflune.layoutengine.html.pagination.PaginationProvider.a(PaginationProvider.java)
at com.objectiflune.layoutengine.html.pagination.PaginationProvider.paginate(PaginationProvider.java)
at com.objectiflune.contentcreation.html.mergeengine.impl.ap.run(ap.java)
… 57 more
