I not able to see any data point in the Tabular Viewer to be able to add an Extraction. Any idea on what setting could be off?
Which emulation are you using…CSV…database?
I would guess the Field Separator is incorrect. You can change it in the Input Data Settings.
In my Input Data setting are below:
Field separator : |
Text delimiter: "
Comment delimiter:#
encoding"windows-1252
line to skip:0
check "First row contains fields names
Everything look correct.
I presume you’ve opened the file in a text editor and double-checked that the separator and text delimiters are indeed those specified in your Input data Settings, right? If you can’t find out what the issue is, can you attach a sample data file here? (Click on the Link icon in the toolbar to upload it).
