For a customer we get new letters every week, like 20 or so, but they often forget to supply all letters.
We dont always check very well and Press will just generate the letters and skip them
Is there a way to get an error for missing PDFs? is it an option somewhere? That way we can make sure we always send out complete files and dont have to contact customers later that we’ve missed something
An option is to run the fatalError(message)1 which triggers a fatal error that aborts content creation, when a condition isn’t met. An code example in which this function is used is present on the following webpage: Dynamically adding sections (cloning) - OL Connect 2025.2 Help
This is also very useful for us. As we had issue having red-crossed images on the centre of page if pdfs were missing.
My question, as I understand, this resource function is available only in Template scripting but not in Datamapper. Is there similar I’m not aware of, to do same thing in Datamapper so we can apply rules for the information being returned by this function (aside from Alambic api we’re using in workflow)?
@upland
I dont know what projects you guys are working on now, but from a customer point view i think many would like it if there was a checkbox somewhere to activate an error report with the output PDF of the files it couldnt find and perhaps any other issues the production encountered - record numbers and what was wrong maybe an idea for a future update?
I think the only way now is to pro-actively look in the logs or not?
A possible solution is to apply something similar to the below and to send the job file to an error process1 when the fatal error occurs by executing the OL Connect plugin to which the template is applied.
