New release: OL Connect Automate 0.9.14 🚀
We are excited to announce the latest release of our OL Connect Automate nodes, version 0.9.14. Here’s what’s new and improved:
Improvements :raised_hands:
  • Mark sets for deletion node : Will mark processed sets (job sets, content sets and data sets) for deletion. In addition to being deleted from the OL Connect server at the earliest opportunity, these sets will also no longer appear in any node queries. This feature can be especially useful in commingling workflows where files are processed on a daily or weekly schedule, or through scheduled tasks.
  • Job statistics node : This node retrieves job statistics for files and jobs processed through the OL Connect nodes, enabling job tracking and performance analysis.
  • Query Items node : Added the flow property so you can now refer to a variable set in your flow directly.
  • Folder capture node : The folder path property can now be constructed through a JSONata expression.
  • Folder listing node : You can now specify the folder path through the msg property.
  • Paginated output: It is no longer necessary to include a paginated job node in your workflow if you are not using any features from a job preset file. This requires updating to OL Connect 2024.1.2 for this feature to work properly.
Important Bug Fixes :bug:
  • Data update node : Fixed an issue where the OL Connect server could give errors when feeding many records at once.
  • Query items node : Fixed an issue where the Match values options would always revert back to the default value ‘All’ after the dialog was saved and reopened.
Updating and installing nodes
To update or install nodes, simply access the Palette Manager within the Node-RED editor. From there, you can check for updates and apply them accordingly. This interface also facilitates the installation of new nodes.
For new comers to OL Connect Automate, utilize the Windows installer available on OL Resource Center: (OL Resource Center ).
This installer streamlines the process by automatically installing necessary components and the latest collection of OL Connect Automate nodes.
A word of caution
The packages are part of the OL Connect Automate stack. It is intended for use by current users of OL Connect who want to experiment with automating server operations through Node-RED. The OL Connect Automate stack is a technology preview .
Support
At this early stage, the OL Connect Automate stack is not supported through the OL Care program. Feel free to visit this forum to post questions, comments and suggestions.
