However when you call new Date() in designer which will treat 26 as month and automatically calculate to year.
That especially confused people if they use date.getMonth() only
Both 26/02/2022 and 02/26/2022 are showing Month is Feb, so that people may think new Date() is working fine with UK format as well
So any particular reason why new Date() is doing an incorrect conversion automatically when date format is wrong in Designer? Or is there any special way to use new Date() in Designer with UK format?
I am not certain why yet but using “26-02-2022” instead of “26/02/2022” does result in “Invalid Date” when applying it the following way in a Standard Script:
Selector: #test
var field, result = "";
field = "26-02-2022"; //"26/02/2022";
if (field !== "") {
var date = new Date(field);
result += date.toString();
results.html(result);
So a quick workaround might be to use…
var date = new Date(field.replace(/\//g, "-"));
…instead of…
…to replace forward slash characters with minus characters.
Thanks for coming back to me, yeah, the date formating is not a issue, we can treat it as string and reformat it easily.
Really appreciate if you can figure out the reason why the same function working is differently, little bit consent if there is anything more different between Js and presConnect Designer Js has not been announced
User scripts (i.e. entries in the Scripts panel) are interpreted by Rhino, which is backed by Java.
2022.1 still uses 1.7.12 but this will be updated to 1.7.14 in 2022.2. This will have many benefits but unfortunately it will not change the behavior of “new Date”.
