Need Step by Step instructions to print a trailing page after all records have been processed.
Please do not provide screen shots as when I zoom in to read the text they are not readable.
If you share a link, please be sure it includes all information needed, with no steps skipped like others I have tried to follow.
I do not have an understanding of metadata and all the options you can do with it, as before it was never required, so please give simple easy steps. (You do not need to explain the steps at this time.)
As I mentioned in the other post, doing this without metadata is not possible in the current version of the software. Also like I said, doing this type of condition is very much in demand so implementation of this feature request should be fairly fast.
I would suggest you open a technical support request at this point. If this is a critical feature for you, someone in technical support can track and escalate the request as needed, and let you know the status of the request.
I am willing to learn the Metadata. However the instructions I have are mission some information with regards to the workflow process.
Someone shared screen shots of an addendum, however when I zoomed in so I could read the text, the text was unreadable.
So if I could get step by step instructions, that are complete with no missing information, I can get this done.
Previous information on step four Building the Workflow process, says to add two actions, but not what goes into the action which is needed before I can click in the rule, to build the rule.
Step 4 of the how-to I linked earlier describes the basic Connect process first, then indicates a single task is to be added. To learn how to use the 4 basic tasks, please watch this module on Learn.
Unfortunately there is no complete instructions for exactly what you need to do, since this would require knowledge of your data and business processes. Any how-to or instructions will always be generic enough to fit for most people while providing the basic steps, and will also assume at least some previous knowledge of the tools used (such as metadata).
Perhaps a course on Metadata would be appropriate at this point, since working with metadata is not only powerful, it’s also versatile. It does require some time to actually explore, however.
Then is the MetaData Objectiflune uses universal with other metadata processes?
I know the javascript for adding a field isn’t the full blown javascript, but inspired by JavaScript.
So before I go and try to find a place that talks about JavaScript will I run into a problem where some metadata techniques are not supported by MetaData?
I will watch the video tomorrow as my day is almost over, however I am confused as to why you need to know about the data and our business?
I am only looking to print a banner page at end of job. This was very easy in planet press 7.
So the data since everything goes into a datamodel should be easy to follow, and should exist somewhere.
