Need help: script for local variable
I have a one page text file.
If the word GST is found anywhere on a line, I want this line to be local variable %1
If the word PST is found anywhere on a line, I want this line to be local variable %2
ex:
        GST                        8.83$
        PST                       17.62$
Hi @nabel1510,
A option is use the following JavaScript code in a Run Script Workflow plugin:
var inputFile = fso.OpenTextFile(Watch.GetJobFilename(), 1, true);
while (!inputFile.atEndOfStream) {
	var textLine = inputFile.ReadLine();
	if (textLine.indexOf("GST") >= 0) {
		Watch.SetJobInfo(1, textLine);
	if (textLine.indexOf("PST") >= 0) {
		Watch.SetJobInfo(2, textLine);
inputFile.Close();
Source: ‘Watch.SetJobInfo() - PReS Workflow 2022.1 User Guide (link)’
thks Marten, I will try it
Please keep in mind that – by using the above shared JavaScript code – if the job file contains multiple lines which contains the string “GST” or “PST” that the latest line will be assigned to the Job Info Variable.
