I have a new printer, a Kyocera TASKalfa Pro 15000c, and I’m struggling to get multiplex to work. The template has two sections, the first set to duplex and the second simplex. But the entire file prints duplex and does not switch from duplex to simplex. I have imported the PPD files and set it up as the following screenshots. It has been a while since I have configured a output preset to use a PPD, so perhaps I have made an error.
Hi Sharne,
you should first check if the duplex and simplex command could be found in the output spool file. Print to a file, then edit it in NotePad or other and search for the duplex command.
You should be able to find the full command each time you print the first section.
Does anything look incorrect to you? The above code snippet only shows twice in the test PS file, yet the PS file has 6 duplex pages. (and 2 simplex pages)
I tried searching for “simplex” and don’t get any results. Is there a better term to search for? I assume duplex false would be simplex rather than “simplex true”.
yes Sharne, Duplex Off is the right command for Simplex(regarding your ppd).
I can see it is activated for page 3(%%Page: 3).
So the Page 1 and 2 must be duplex I suppose, then page 3 simplex. Which seems to be the result you would like.
You should check if Page 4 get a duplex command, and page 6 a duplex off one. If so the spool file seems to be good.
So maybe the printer cannot accept mixplex (switching from duplex to simplex) or the duplex commands could be wrong. You could try another ppd file.
