I have an extraction on data mapper about several tables for products importations items, what i want to accomplish its from this data, i need to do a query to a db on workflow via scripting for comparison and validation, but how do I get the data on the extraction to get into a workflow variable, Are workflow global variables multivalues?
You could have you results put into a JSON and set that JSON to a Workflow variable.
Its there any documentarion on how to do that or where i can get more info about it.
Thanks for your help,
You could look at what the JSON structure is on this site.
Then in your script you will use the JSON.stringify() and put that in a Watch variable.
