Multiple users in Connect
In Planet Press Suite we had the designer. With Designer, you were able to have multiple users working individually at the same time because they were running individual installations. They could then send the documents they were working on to Workflow installations that they had permissions to.
It appears that the Connect designer will only install on the server. Is there, currently or planned, a method to allow multiple users to design documents concurrently?
Thanks!
The Connect Designer will install anywhere you want it to. You can have unlimited instance of the Connect Designer as well. Each user can have its own version of the Connect Designer. Of course, it still is not supported in a multi-user server (like Terminal services).
