Hi all,
i have flow to get email from M365 and save the attachment to a folder if it is a pdf file.
but some of the emails got the below error :-
22:31:55.147 [0025] W3831: Invalid filename : c:\programdata\objectif lune\planetpress workflow 8\planetpress watch\spool\59.tmp\010ef0?1868s349\010ef0?19dabf4b.pdf
22:31:55.147 [0025] Load External File: W1603 : Plugin failed - 22:31:55 (elapsed time: 00:00:00.000)
22:31:55.147 [0026] W3001 : Error while executing plugin: W3223 : Copying file C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\59.tmp\spl010EF0I1ENLPW8421B4C9B.xml to D:\PO\SOURCE1\XXX\010ef0?19dabf4b.pdf failed: Error code 123: The filename, directory name, or volume label syntax is incorrect.
pls help.
Best regards
Joey
