if input file in capture folder it takes long time in spool folder temp 1 i please give me any guesstion abut my process totally stuck for 19 hours please give me any suggestion.
Try the following:
- Open the Workflow Services Console and check whether there are errors in the Workflow logs and report them here.
- Check that the OLConnect_Server service is started so the Connect Server can process jobs handed to it by the Workflow
- If you run the job in debug mode, can you reproduce the behavior? If so, are there any errors?
- Are you able to produce output in the Designer using your data mapping configuration, template and output presets?
- If there are no errors and you think it is simply a performance issue, please take a look at the following links: PReS Connect 1.8 User Guide https://learn.objectiflune.com/howto/connect-performance-optimization-megathread/ PReS Connect 1.8 User Guide
