Hello have a upcoming job which im trying to run a trial for.
Essentially its a overseas client that wants to prepare invoices, they need the proofs back as PDF, however every individual record to be in a seperate PDF file, with the name of the file being _.pdf
I have looked through the tutorial and its not working for me.
First I merged Account No and Surname in excel so the field is already in the format required.
Then i goto Job Creation, Include MetaData, I have tried both Document Set Tags and Document Tags with Tag Name “Sort” Source Type “Field” Source “The actual data Source”
Then i goto Output Creation, Select Model Generic PDF
Output Type Directory
Job Output Mask
${set.metadata.Sort}.${template.ext}
Separation at Document Set level as Document level no longer works.
Thank you very much, turned out I hadnt updated and was still at 1.7 I also think i forgot the key point of loading the job creation preset on the first page of job output.
