Is there an easy way to duplicate a print page?
Hello - I am trying to dupicate a print page because I need to show the exact same thing except for one minor change based on a condition. Is there a way to duplicate or copy a print page? I have gone into the source code and copy and pasted that into a new section. This seems to mess up the section I copied it from. Where I copied it to is fine but where I copied it from is not. The code is fine but the design view is really distorted. I can copy one div at a time and that seems to work but this has a lot of information in and isnt very efficient.
Any help would be great.
Thank you
Amy
Hi ahaddad
If copying the source of your section to another section does not work then try copying the source to the master page. The master page content will then be on every print section. Then on each section add the difference between the two.
Hope that helps.
