I am trying to figure out the best way to change the css of a print-context page depending on the record in a data field. So far I have been doing it in a rather messy way, changing each class depending on that field. But it would be neater if I could just have separate stylesheets for each scenario, and a script that would load that stylesheet if the data field condition was met.
I have managed to cheat a little and create a html snippet with the
Generally speaking, it’s only necessary to change a whole stylesheet if the whole design of your document (or website) changes completely - often changing stylesheets is used to “theme” website.
It would help to know what it is that needs changing before I can help you determine the best method to do it - in web technologies, every challenge has its own solution(s)!
But here are a couple of hints:
Use classes rather than inline styles. You can have more than one class to any element and classes can be shared between multiple elements - so you can affect change on a lot of elements in one fell swoop.
Styles are inherited, aka they will propagate down to children elements. For example, if you want to make a table row bold or have a background, you apply that style to the <tr> element, not each <td> individually.
CSS selectors are really, really powerful. You can things like “apply this style to: links that have no alternate text which are within the menu div but only if they follow a line separator with a specific class”. I’m not kidding ( #menu > hr.line + a:not([alt]) { /* styles go here */ } ) and this is… actually still a pretty simple selector. Here are some search results for more info.
To add a little more detail, we are printing a document where the text stays the same, but the branding will change depending on a data field (company). So Each company has a different stylesheet and logo but all the other data stays the same. I have indeed so far done as you suggested and had lots of little rules, but when a new company is added it gets fiddly. That is why I wondered if there was a way to do something along the lines of (I know this doesn’t work but just to show what I mean):
if (record.fields[“Business”]==“BusinessName”) {
results.replaceWith(loadhtml(“Stylesheets/BusinessName.css”));
Awesome, I was needing this exact script, dynamically change the stylesheet href value. I will say the code was 99% correct. Minor change and it worked(changed “src” to “href”):
