Is there a limit to number of sections in a template?
I am creating a complex template and when I go to save it get the message “ERROR: Pagination: WARNING Pagination limits reached”.
Is there a limit to the number of sections in a template or anything else that I should be looking for? I could possibly simplify the template by combining anything that doesn’t need to be conditional into a single section, however I will need at least 16 conditional sections.
Hi Douglas,
Which version are you using?
Hi Erik
It is 1.6.1.
Doug
Don’t think this is related to the number of sections but suspect content in one of the sections. Could you try pinpointing a specific section by removing them one by one and saving the template under a different name?
I removed the section I added most recently and this removed the issue. For some reason I seemed to end up with 9999 pages in the section!
Good catch, so now the question remains what is causing that. Could it be a script?
I’ve added in some more sections which now just call PDFs as static backgrounds with no variable content to be overlaid. These new sections all show the expected number of pages when I look at them. I can now save the template however when I try to send it to the workflow I get the “hourglass” for several minutes and then get the “Pagination” error message as above.
I’ve tried disabling all the scripts but I still get the Pagination error. Any ideas as to where I should now be looking for what is causing this?
Its hard to determine without seeing the template. Suggest to contact Tech Support and have them investigate.
