Internal Server Error
Where can I find documentation on the various error messages? This one is baffling me:
ERROR: 22:45:46.899
W3001 : Error while executing plugin:
HTTP/1.1 500 Internal Server Error LoggedApplicationException:
There was an error running the output creation process caused by ApplicationException: null
(SRV000042)
Hi TDGreer,
Here is the error you are getting in workflow. All error codes are listed under Workflow->Error Codes in the left pane in the knowledgebase. However, I’m not sure why you are getting that error. Could be a bunch of things in your output preset that is returning a null.
That’s the generic error code. I’m looking specifically for how to troubleshoot the “Internal Server Error”. There’s nothing wrong with the Output Preset; this particular process/template runs every day. On one particular day, the job failed, and this was the logged error. I have no idea what it means or how to mitigate it. I re-ran the same job the next morning with no errors.
If that is the case you would need to try and reproduce the error and then open a support ticket with OL so they can investigate further. You could also look at the Workflow logs and see if they contain more info. (but you probably tried that already)
