Input file name
HI,
can you guide me how to display in the designer the input file name?
i try in the script
var result=“”;
result=%0;
results.html(result);
also data.filename
thanks
Starting with OL Connect 2022.2, the data filename can be accessed through the automation.properties.originalFileName property.
hi Phil,
i cannot set or locate automation.properties.originalFileName
is it possible that i can get the file name on the datamaper side? so i can call it in the design?
Yes you can:
