Imposition NUP problem
We have a C9 access mail licence process the outputs a multi page machine barcoded PDF to A4 that contains different length documents everyday
I have done a task in pres to convert it to A3 Imposition (NUP) which works ok and outputs the A3 pdf but if i put a big file in with a lot of pages (20,000) it fails and just outputs the pdf exactly the same (A4) as when I put it in
I have attached the log fie which it produces showing the following error
Thanks for looking
WPROC: C9 A3 Imposition-NuP (thread id: 11796) - 10:15:06 AM
DEBUG: 10:15:06.619 [0001] Starting plugin Folder Capture - 10:15:06 AM
DEBUG: 10:15:06.619 [0001] Mask: *.pdf
DEBUG: 10:15:06.619 [0001] Parsed mask: *.pdf
DEBUG: 10:15:06.619 [0001] Input path: D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_input
DEBUG: 10:15:06.620 [0001] Parsed path: D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_input
DEBUG: 10:15:06.620 [0001] Number of masks: 1
DEBUG: 10:15:06.620 [0001] Using mask: *.pdf
DEBUG: 10:15:06.620 [0001] Found 1 new files in “D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_input”
DEBUG: 10:15:06.620 [0001] 1 file(s) found
DEBUG: 10:15:07.128 [0001] Processing file D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_input\20211027075508_Wednesday_c9_010BKXJ2GHE0W1C.pdf
INFO : 10:15:07.324 [0001] File captured : C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\46.tmp\job010BP9F0E3E4HEE243CD0A0.dat, size: 50040854 bytes
INFO : 10:15:07.324 [0001] Plugin Folder Capture completed successfully - 10:15:07 AM (elapsed time: 00:00:00:705)
DEBUG: 10:15:07.324 [0002] Starting plugin All in One - 10:15:07 AM
DEBUG: 10:15:07.324 [0002] Default Server IP address: localhost
DEBUG: 10:15:07.324 [0002] Parsed Default Server IP address: localhost
DEBUG: 10:15:07.324 [0002] Default Server Port: 9340
DEBUG: 10:15:07.324 [0002] Parsed Default Server Port: 9340
DEBUG: 10:15:07.324 [0002] Default Username: sysadmin
DEBUG: 10:15:07.324 [0002] Default Parsed username: sysadmin
DEBUG: 10:15:07.325 [0002] Create the rest client
INFO : 10:15:07.326 [0002] Source is Data mapping configuration: C9 A3 Imposition-NuP_DataMapper.OL-datamapper.
DEBUG: 10:15:07.330 [0002] Sending data file…
DEBUG: 10:15:07.734 [0002] Using cached data file (id = 84380)
DEBUG: 10:15:07.736 [0002] Using cached datamapping config (id = 84366)
INFO : 10:15:07.736 [0002] Template: C9 A3 Imposition-NuP_Template.OL-template.
DEBUG: 10:15:07.737 [0002] Using cached template (id = 84367)
DEBUG: 10:15:07.737 [0002] Starting PDF/VT operation…
INFO : 10:15:07.802 [0002] Output preset: C9 A3 Imposition.OL-outputpreset.
DEBUG: 10:15:07.803 [0002] Using cached output config (id = 84368)
DEBUG: 10:15:07.824 [0002] [2021-11-10 10:15:07.824] Print> Retrieving results
ERROR: 10:25:38.099 [0002] W3001 : Error while executing plugin: HTTP/1.1 500 LoggedApplicationException: There was an error running the content creation process caused by Error: Pagination: WARNING pagination limits reached.
ApplicationException: Error: Pagination: WARNING pagination limits reached.
ERROR: 10:25:38.099 [0002] All in One: W1603 : Plugin failed - 10:25:38 AM (elapsed time: 00:10:30:775)
DEBUG: 10:25:38.100 [0003] Starting plugin Send To Folder - 10:25:38 AM
DEBUG: 10:25:38.100 [0003] Path: D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_output%y%m%d
DEBUG: 10:25:38.100 [0003] Parsed path: D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_output\2021\11\10
DEBUG: 10:25:38.100 [0003] Filename: %o.pdf
DEBUG: 10:25:38.100 [0003] Parsed filename: 20211027075508_Wednesday_c9_010BKXJ2GHE0W1C.pdf.pdf
INFO : 10:25:38.172 [0003] File sent : D:~RC tech support~\C9 A3 Imposition-NuP\C9 A3 Imposition-NuP_output\2021\11\10\20211027075508_Wednesday_c9_010BKXJ2GHE0W1C.pdf.pdf, size: 50040854 bytes
INFO : 10:25:38.172 [0003] Plugin Send To Folder completed successfully - 10:25:38 AM (elapsed time: 00:00:00:072)
WPROC: C9 A3 Imposition-NuP (thread id: 11796) complete - 10:25:38 AM (elapsed time: 00:10:31:564)
Dear @fergal,
First of all, welcome on our OL Learn forum!
Based on the shared information I would like to suggest to open a technical support ticket via our website because we probably have to investigate the Connect logs plus the PDF input file and used Connect resources to find out what is causing this issue.
