Importing graphic from web address
Greetings,
Is it possible for PrintShop Mail to pull a graphic from a web address and place it in a card template. Here is an example of the Variable result:
(https://s3.amazonaws.com/static.contentres.com/printmail/amazingmail/assets/print-ready/BdayCandle_front.jpg)
Cheers & Thank You,
Steve
You may could be done as online image used an image option in the template as give a specific the protocol (http or https), and then enter a web address
https://help.objectiflune.com/en/printshopmail-connect-user-guide/2021.2/#designer/VariableData/Dynamic_Image.htm
Thanks you Tosuji. I think I have the variables set up correctly but it’s still not pulling the images.
