Image convertion
Question, I have a workflow that create a PDF file with the all in one plugin. It’s work fine, now I want to convert that pdf created to a JPeg. When I created a proceess that the input is the folder wher I placed the PDF to convert and I put the Image plugin, I have the error , undefined file name in the poecess of the image ! But if I place the image plugin just after my all in one it’t work, but I don’t have the JPeg that I want, it missed the information that the all in one put on the PDF. What I missed ?
anyone have an Idea ?
Hi TeasdaleR,
Are you merging the input PDF with a template in the Image output task? If so, does the template use dynamic images? Also make sure to run in optimized postscript and not in printer centric in the Image output task. Make sure to set a valid file name for the output, try for testing purposes to put a static name.
If it still fails, please open a support ticket, this should work. Thanks.
Hi Jouberto,
Am I correct in saying that the only way to output your PlanetPress Connect template to JPG requires a PlanetPress Image license?
