I am receiving an error message: "TypeError: OL_extension_getLayoutOffset(...) is null.
Hi, this error may occur if some datas are printed over the bottom margin (or just at its limit).
I suggest you verify this or specify a smaller margin and make a test
I did get that error from a customer because in his scripts, he was removing details table when not needed and that causes an internal process (which handle the overflow) to get the wrong value for the page length. If it is the case here, the solution was to hide the unused table instead of removing them.
I’m still receiving the error and I’m not sure why. Any other suggestions?
Multiple reasons were causing that error. Most of them are fixed in Connect 1.7. Can you update to that version?
If the problem persist with that version, I suggest you open a technical support call at 1-866-348-863 or through our webiste.
