How use automate parameter
In the Connect 2018.2 I had the following setting - Counter, Automation variable, String, ‘0’.
In the Preprocessor step proterties->properties->scope->[Entire Data][Each Record][Automation variable]
Now in the Connect 2020.2 is:
Preprocessor step proterties->properties->scope->[Entire Data][Each Record].
The variables is deprecated; Now i need use automation.parameters instead.
I can’t set a setting like before? What is the correct sequence of steps? What am I doing wrong?
The automation variables are deprecated, but they still work like they did before. It is recommended to use the runtime parameters, but you are not forced to do so.
Yes, Phil, that’s how it is.
But how i can initialize automation variable in the scope, if i can choose only between entire data or each record?
In your data mapping configuration, your automation variables are automatically transferred to the Parameters tab (if you don’t see it, go to the Window menu, and select the Show View > Parameters.).
The runtime parameter will have the same name as your original automation variable (let’s call it MyVariable).
In Workflow, when you double-click on the DataMapper task, you’ll see that MyVariable automatically appears in the list of runtime parameters. This makes it a lot easier to manage the parameters required by the DM config since you see them listed in the DataMapper task, without having to open up the DM config to find out which variables are expected.
Hi, Phil
Everything works.
Thanks for your help!
