How to Sort in Dynamic Tables
Hi Guy,
How can i sort data using dynamic table. Can i able to sort the data inside the dynamic table like total amount of the items.
Hi Ggan,
Currently that is not possible as part of the merge process. This needs be handled up front.
hi Erik
even in connect design there is not possible ? i want to sort only the amount of the table
You can either do it in Workflow or in the pre-processor of your Datamapper. But in both cases, you will need to write a script to do it.
You could as well adapt you data extraction as to read the data in the order you want it but that would make it a lot a more complex.
BTW, I have open an improvement request with our R&D asking for the ability to sort detail table, not that there is any garantee that it will be done.
The more ask for it, the higher the priority.
In reference, the request number is TS-6228
