Some printer use Media Position as absolute and override other settings so delete the Position entry so you just have
weight, type and color…
This should work for most PS Printers.
this definitely works on Xerox Freeflow, KM native controllers, I believe Canon native Prisma Controllers ( those that follow the standard setpagedevice rules) , I am unsure about Ricoh…
With these setting if you use a Fiery Rip you need to use SPD mapping.
May I please confirm if this solution proposed by @weinhandlh is still considered correct in Planet Press Connect?
We’re using an enterprise grade printer with 5 trays, and we need to ensure that tray selection is automatically selecting other available trays when the paper runs out.
I set the media name, this media name matches a media name in the output preset, and in that we match the media name to a specific tray of the printer. There does not appear to be support to select multiple trays, or hand type a tray name.
I was previously told by phone that there was a way to separate the trays using a semi-colon character, but I cannot recall the specifics. Is this tray selection done through the output preset media → custom script, or via the Template → Section → Sheet Configuration → Media → Custom Script ?
