I need to customize the slip sheet with some information relating to the job.
Thanks,
Sergio
Thanks,
Sergio
You could create another Section/Context and use a Control script to control its output…
Hello Sergio,
You can look at the following how-to which describes how to add a custom cover page (or slip sheet) at any level including the Job. There are pros and cons to this method, described on that page:
Is there another place to find this example?
I have corrected the link above. Try it again.
Thank Phil, sadly not what I was hoping for. Need a Slip Sheet with a field name on it. I will keep looking.
Thanks.
The link above (how to description) shows the way to create a personalized slip sheet (you can use your data fields on that slip sheet section). Where do you stuck?
