How to create Output PDF with restricted editing
I have a client which i am required to export single PDF files and then restrict the editing of the PDF files so the end user can not alter the files. In adobe it would be to set the settings in the below image, is there a way i can do this is designer?
Thanks is advance, I’m fairly new to this so it may be something obvious i’ve missed.
Wayne
Hi Wayne, you can set a password in the output creation settings.
There is a security tab when you select PDF output. Here you can add a password to avoid changing the document.
Check this print screen:
