Hiding elements in detail table
What javascript code would I use to hide the barcode in a detail table if the barcode value is empty?
Attaching a picture of the output I get now, using a script on the barcode object that includes a condition.
My code looks like this:
if(record.tables["leftCol"][index].fields["left_128ABarcode"] !== "undefined")
	var field, result = "";
	field = record.tables["leftCol"][index].fields["left_128ABarcode"];
	if (field !== "")
	 result += field;
	this.text(result);
else
 this.attr("data-conditional", "");
 this.hide();
I believe you’re going to want to select the barcode object and set the CSS Display property to none, as below:
Thanks! using the css display property as ‘none’ did the trick!
