Hiding an Entire Page using Conditional Scripts
I’ve read about hiding certain elements like images and paragraph in PReS Connect Designer using Conditional Scripts, Is it possible to hide an entire page using the same procedure. For example I have a 4 pager Letter and I want to Hide Page 2 if a certain field has a specific value.
If the page is represented by a print section you can disable it in a control script.
You cannot hide individual pages wihtin a section but when using separate sections you could use a Control Script to show/hide the respective section. In version 1.8 we will introduce a script wizard to achieve that, this way you don’t need to write a script.
To dynamically show/hide a section in your output using a Control Script:
var section = merge.template.contexts.PRINT.sections['Section 2'];
if (record.fields["province"] == "QC") {
    section.enabled = true;
} else {
    section.enabled = false;
Hope this helps,
Hi Erik!
As PReS Connect 1.8 is already released, could you tell me, if this script wizard mentioned above is available, where can I find it?
Kind regards,
Roland
Hi Roland,
Simply right mouse click a section in the Resources panel and choose Make Conditional… See also: PlanetPress Connect 1.8 User Guide
Best,
