Maximum data line length exceeded
all we are putting on is OMR, nothing else, not even reading the address, but it appears in the middle of one address in particular, w/ really long fields.
Hi @jkornit,
Can you let us know please when the error message “Maximum data line length exceeded” does occur? Is that by viewing the Data Mapping Configuration file in the Connect Designer, by viewing a Print Context Section in (Connect Designer) Preview mode, by printing via the Connect Designer or by running a Workflow process?
oops. sorry about that. i guess context helps.
this is on the resulting pdf. it is PPC running w/ a ptk file from PP7 imported into the workflow.
The PressTalk interpreter has a limit of 65535 characters on the length of a line of data for the text-based data file types (line printer, ASCII, Channel Skip, CSV).
the text is a long address, but not nearly 65k characters.
In fact, it is under 150 characters.
