Good Morning,
We are wanting to generate XML from some data that we have from some clients, this for later to be able to sign them digitally.
Within the Designer, I configure the data (in this example they are forced data) but maintaining a structure of a mother node and several groups with sub groups within them.
If I do the test with the Workflow I add a step of Execute data assignment with the .datamapper inside and I select the option of “Output Results in xml data file” it generates the XML but without respecting the groups, it is as if for the Connect there were no groups.
I enclose the datamapper, with an example of the XML that we must generate and how it currently generates me, to see if something I am doing wrong and if they could give me a hand.
From already thank you very much.
