Folder Capture: Found 0 new files
Hi there,
got a question. I’m usting the “Folder Capture” some what half way my workflow.
In case there are 0 new files found I need the workflow to go to an other process.
I tried “On error go to process”, but the workflow does not see it as a workflow.
I trying a text condition, (in branche) but because there are 0 new files it does not reach the Text Condition.
Can anyone help me out.
Note* The goal is to send the workflow to an other in case there are 0 new files found. This other process has a delay (sleep) and goes back to the previous process to try and capture again. Any other workaround is welcome.
Instead of the Folder Capture task, use a Folder Listing task. You can then easily determine if the total count of files in the folder is 0.
Thanks I found the Task, at first glymps I seems to have the same effect, how can I interupt?
Got it to work Thanks Phil
