I’m having problems selecting media, trays and paper size for printing on the Fiery RIPs. The output settings appear to be ignored on the Fiery.
Does anyone have a solution to the problem? I think this has been reported before but the solution has not been published.
Yann
2
Hi, with the lastests versions of Connect it is now possible to import the PPD. Did you tried to do so and select medias accordingly. You could find some information on this link: http://help.objectiflune.com/en/pres-connect-user-guide/2018.1/#designer/Output/Print/Interface/Dynamic_PPD_Options.htm#toc-0
Thank you. I’ll check this out.
