In the OL Connect Designer/DataMapper, UTF-8 is fully supported. Obviously, your data must be truly UTF-8, which is not always the case, especially with XML. In XML, the lack of an encoding attribute in the <?XML ...>
header means that the file should be interpreted as UTF-8. But many applications just don’t include the encoding attribute, even if the file contents are actually using a different encoding.
For instance, an XML file encoded using the generic Latin encoding used in western countries must be marked this way:
<?xml version="1.0" encoding="ISO-8859-1"?>
So if your XML file is properly encoded and marked as such (or unmarked if it truly is encoded in UTF-8), then it will work just fine in OL Connect Designer/DataMapper.
That said, the OL Connect Workflow module is not UTF-8 compliant. Well, to be more accurate: a lot of it is not. As soon as you read from/write to the data file, Workflow uses the machine’s default locale to determine which encoding to use. Note: in this case, writing/reading means “writing/reading content to/from the file”, it does not apply to file operations like copying, uploading or moving a file.
So with UTF-8 files, these operations go through a conversion process, which can lead to data loss. Also, when you type a specific value in any task’s fields, that value is encoded using the same locale encoding, so those values may be converted as well when written to a file.
There are some exceptions to this: Workflow’s Metadata is natively Unicode-aware. As long as you don’t manually write to/read from the file, the UTF-8 encoding is preserved. For instance, if you use an Execute Data Mapping task with a UTF-8 file and set the option to store the records in the Metadata, those metadata records will contain the correct values.
However, if you wanted to write those values to a file while retaining their original encoding, then you’d have to use a script because Workflow’s Script Engine is also Unicode-aware while, for instance, the Create File task is not.
Hopefully, this gives you a better idea of the potential pitfalls of using UTF-8 data.
Final note: before anyone asks, no, we can’t convert Workflow to a unicode-aware application as it would require a huge amount of work because of the language platform it was developed with. Just like we can’t convert it to a 64-bit application. That’s why we are developing, in parallel, a series of nodes for Node-RED that will, in time, be able to achieve most - if not all - of the operations currently available in Workflow. In 64-bit. And in Unicode.
