We made a very simple workflow where we:
- look for new PDF files from an Input Folder plugin
- Use Alambic to check pages rotation
- Send them to two different folders
The Send to Folder plugin sometimes throws the following error, almost randomly. In a set of 100 files just one or two go into error and not always.
ERROR: 05:00:50.673 [0016] W3001 : Error while executing plugin: W3223 : Copying file C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\99.tmp\job010GEJ5RW05671A3DE923C3.dat to \\<redacted network path>\<redacted filename>.pdf failed: Error code 3: Impossibile trovare il percorso specificato.
What could be the issue and how could we fix it?
