Error When try to sent to configuration
Does anyone know the reason why this error occur when I am try to sent to configuration?
W1533:Error while Sending the configuration file
w1534:error while saving the configuration file:
Could not move temporary save file:Error code(): The operation completed successfully.
Please advise why I cannot sent to configuration on Workflow.
Are you logged on as an administrator? The Workflow service expects to be able to write the config to the C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch folder. Check if you have writing rights to that folder.
Also, make sure there’s no undefined task in any of your processes. This sometimes happens when you delete an Output task you’d added before but don’t replace it with a vaild alternative.
The path does not exist in my c drive.
This is the close I see on my C Drive.
C:\Program Files\Objectif Lune\OL Connect
Well that explains that: if you can’t even see the Programdata folder, it means you probably don’t have the rights to send files to it or to one of its subfolders. Ask your IT department how to change that.
